Horn stuck on.
Old Apr 29, 2018 | 06:53 PM
svo's Avatar
svo
Default Horn stuck on.
01 Z06 Replaced the membrane switch with a new one, new relay, fuse good, Horn still stuck on. Tested the old membrane and it is still good.
I've checked the wires behind the airbag, and all that seems good. I've searched the net as well and only find info on replacing the membrane switch.
What else could be causing this?
thanks.
Old Apr 29, 2018 | 11:44 PM
svo's Avatar
svo
I am assuming you mean the horn relay control which is on the left of the diagram, and not the Relay #36?
I did not know about that relay on the left. Thanks for the diagram.
Old Apr 30, 2018 | 10:44 AM
svo's Avatar
svo
Ok, I did swap the relay 36 already. It clicks on when it is plugged in.
Old Apr 30, 2018 | 02:41 PM
svo's Avatar
svo
Roger that. I will try to get out there and figure it out soon! Thank you for the info.
Old Dec 7, 2018 | 11:56 AM
svo's Avatar
svo
The problem with my situation ended up being the Turn signal switch.
I made a pic of the issue.
Hope this can help the next guy who will be pulling his hair out trying to figure this out. lol
Old Dec 16, 2018 | 09:26 PM
Leenorm1's Avatar
Leenorm1
My horn fuse has been out for a while as my horn will turn on at times by itself. i will definitely use these notes. Thanks guys!
To Horn stuck on.
