Moving from LS1 block to LS2 for forced induction
Old Apr 30, 2018 | 10:46 PM
BURL's Avatar
BURL
Default Moving from LS1 block to LS2 for forced induction
Will be replacing LS1 in 2003 C5 with Forged LS2 block for FI. What covers etc. will I need? Is it possible to keep the LS1 style covers and cam sensor on an LS2 block or must I upgrade to the front mounted LS2 style engine cover? I know a harness adapter is available. I will be keeping the LS1 computer so I will need a 24 tooth reluctor which I think will not be a problem as I can order that with the rotating assembly. I am confused as online I see covers listed as for LS1/LS2. How can they be both?
Those who have done this could you give me a run down on what I need to transplant the LS2? Thanks
Old May 1, 2018 | 08:54 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
On my motor I went with the LS3 block for the added displacement on the stock crank. I used an adapter harness and converted to LS2/3 cam and knock sensor locations. Worked like a champ on my setup.
Old May 2, 2018 | 12:24 AM
BURL's Avatar
BURL
Default Ls1 to LS2
Yes, but can you tell me what covers/parts ( front, rear, valley, oil pump, timing chain. etc) that are specific to the LS2 and the LS1 parts can't be used??
To Moving from LS1 block to LS2 for forced induction
