2003 Corvette brake pedal
Old May 1, 2018 | 11:22 AM
BayVette's Avatar
BayVette
Default 2003 Corvette brake pedal
If I let my foot slip off of the brake pedal, after applying the brakes, it makes a dull thud noise upon returning to its resting position. Is there some kind of a bushing or ? that is meant to muffle the noise? If so, mine may be in need of replacement.
Thanks in advance!
Jerry
Old May 1, 2018 | 10:43 PM
Moved to C5 Tech.
Old May 12, 2018 | 08:39 PM
jaki30's Avatar
jaki30
Default Need assembly diagram of C5 brake pedal assy.
My 2004 has a somewhat similar feel/sound when using the brake pedal.
I suspect that there may be a bushing or some sort of pivot for the brake pedal as part of the hanging pedal assembly. Mine is a manual trans. so I do have a clutch pedal.
However, I can't seem to find any definitive diagram of the parts. Just a couple advertisements for brake pedal bushings at the local auto parts places.
To 2003 Corvette brake pedal
