C5 Headlight - Operation Sequence ?
Old May 1, 2018 | 11:13 PM
tdf's Avatar
tdf
St. Jude Donor '11
Default C5 Headlight - Operation Sequence ?
When I trun on my "Parking/Running Lights" the headlight doors open. I don't think that should be the case. I don't even think that has always been the case?
Do other C5 owners have headlight doors that open when headlights are not turned on, only yhe Park Lamps?
Old May 1, 2018 | 11:32 PM
Leenorm1's Avatar
Leenorm1
Default Headlight operation
my lights worked correctly and then began doing what you described. However at the same time that was occuring one of my gears went bad and the light would fall down with the bad gear. I took the housing out disassembled the motor replaced the gear and put back, and now the parking / fog lights can turn on without the lights flipping up again.
Old May 1, 2018 | 11:47 PM
My Vette Life's Avatar
My Vette Life
I second that gear situation. I have the new gear just not installed yet.
Old May 2, 2018 | 12:01 AM
tdf's Avatar
tdf
St. Jude Donor '11
Bingo. I have a failed gear (grinds when it reaches the down position) on the right side. Gear is ordered.
Thanks for the help guys. I didn't know whether the two issues were related!
Old May 2, 2018 | 10:22 AM
OUTAKTRL's Avatar
OUTAKTRL
Gear needs replacing
Old May 2, 2018 | 01:57 PM
3sACROWD's Avatar
3sACROWD
Hopefully the gear replacement is the fix.
As info, a correctly operating system will allow the headlights to be up and off with he parking lights on. To accomplish this, you turn the headlight switch to turn on the headlights then quickly turn the switch back to the parking light position.
If your gear replacement doesn't work, you may have a worn out multifunction switch.
Old May 3, 2018 | 04:19 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Are u sure that your (Search: Keyword(s):on the forum----- sentinel, settings)is not turned on..
mike v
Old May 3, 2018 | 04:42 PM
Velocity_Vette's Avatar
Velocity_Vette
The Twilight Sentinel feature typically accompanies the head lights actually turning on (that's part of their function actually; to operate headlights automatically). As the OP is describing a situation where the multi-function switch is turned to parking lamps with accompanying flipping up of the headlights but them still off suggests Twilight Sentinel is not the immediate issue.
However of concern is the aforementioned action of turning to parking lamps but only getting headlights raising but not turning on. Myself personally that seem to suggest a multi-function switch issue. I'll detail.
The internal headlight gears themselves are all mechanical; there's nothing electrically that tells the headlight motor "if" and "when" a headlight has been turned on or off sans the main headlight relay. The on/off function is controlled directly by the wiring going into the headlight bulbs themselves. If the headlight switch (multi-function) switch is being turned to parking lights but then the headlights raising up without turning on then that tells me that the contacts inside the multi-function switch are having issues.
It is an extremely common issue with C5s and eventually what will occur is that there will be a situation where something won't operate at all because the contact(s) will be too far worn. Ex: cannot flip the headlights up electrically, no on/off function, etc.
To C5 Headlight - Operation Sequence ?
