Push-button ignition?
Old Oct 17, 2002 | 04:40 PM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Default Push-button ignition?
Just thinking outloud here. Not something I would do to the current car since I need to get one that will be reliable.
What would it take to replace the key ignition with a push-button ignition? I already have a security system which comes with a keypad security. That part is not currently installed, but I can add it when I remove and re-install the security system on the new one. I'm thinking I would either need to wire in the correct resistor or hide one of the keys behind the dash to make this work. But I thought it would be a little different to have the button instead of the key ignition.
Has anyone out there done this yet?
The only drawback I see would be in the valet seat / steering wheel movement not working. I'm sure I could figure something out though.
Old Oct 17, 2002 | 04:57 PM
wwashing's Avatar
wwashing
Default Re: Push-button ignition? (Brett C5 SCCA)
I'd start by investigating how those remote start systems work! :cheers:
They have to bypass the security system.
[Modified by wwashing, 2:58 PM 10/17/2002]
Old Oct 17, 2002 | 05:33 PM
brianw21's Avatar
brianw21
I saw an implementation at ces last year that was as follows:
The Keylock cylinder was relocated, and filled in. The lock cylinder then was fixed with the key in the cylinder and on.
a few relays were used in conjunction with a microchip pass key (or your key panel. The last relay was wired with a push button to the start side of the lock cylinder.
This seems like a cluge, but there was no good way for them to start the vehicle without the computer seeing the pellet. :)
Old Oct 17, 2002 | 06:15 PM
Flyin'Brian's Avatar
Flyin'Brian
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
You can turn off VATS with LS1-Edit :)
[Modified by Flyin'Brian, 5:38 PM 10/17/2002]
Old Oct 17, 2002 | 06:34 PM
jpas's Avatar
jpas
Just an FYI,
The C6 has a push button starter. I sat in a mule a couple of months ago, the new interior is pretty slick!!!
Old Oct 17, 2002 | 09:15 PM
Mean Green's Avatar
Mean Green
CI III & IV Vote Ho
CI II, III, IV & V Vet
CI IV Bracket Champ
St. Jude Donor '03-'04
Default Re: Push-button ignition? (jpas)
Just an FYI,
:eek: :eek: :eek:
Old Oct 17, 2002 | 10:04 PM
AP's Avatar
AP
Where? When? What?
Just an FYI,
Details !!!
Old Oct 17, 2002 | 10:27 PM
jpas's Avatar
jpas
Default Re: Push-button ignition? (AP)
Sorry I cannot reveal any more info about the C6 without getting myself into trouble with GM.
Old Oct 17, 2002 | 10:30 PM
AP's Avatar
AP
Do you work for them?
Old Oct 18, 2002 | 12:01 AM
jpas's Avatar
jpas
I work for a supplier that is doing the oil cooling system and the frame for the C6 (AKA GMX215/245). There was a rumor that 14 GM engineers were let go for talking about the C6 engine valve train. It is some pretty trick stuff!!
To Push-button ignition?
