Heat and air conditioning
Old May 7, 2018 | 09:26 PM
Wtowns51's Avatar
Wtowns51
2nd Gear
Default Heat and air conditioning
I have a 1998 corvette and the heat and air conditioning will not blow much air through the vents.
Old May 7, 2018 | 10:51 PM
001pewter's Avatar
001pewter
St.. Jude Donor '17-'18
Sounds like a vacuum problem, if it blows from all vents in different modes it is a vacuum leak. There's a vacuum hose behind the manifold that's prone to failure, lines underneath the battery, and a vacuum canister down there as well.
Old May 8, 2018 | 01:07 AM
Moved to C5 Tech.
Old May 9, 2018 | 08:47 PM
Wtowns51's Avatar
Wtowns51
2nd Gear
thanks 001 Pewter, I will check that out.
To Heat and air conditioning
