Window Regulator
Old May 8, 2018 | 08:08 PM
VetteC6Dan's Avatar
VetteC6Dan
Default Window Regulator
My passenger side door is starting to make some serious "grinding" noises when going both up and down.
I am planning to replace the window regulator.. when looking up the part on gmpartsdirect and other gm parts sites it is saying that a special connector also needs to be ordered?
I am wondering if anyone who has had to do this repair is familiar with the additional connector that is needed? When looking at aftermarket options it is not mentioning this connector?
As always I appreciate everyones help.
Old May 8, 2018 | 08:21 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Perhaps this will be of some help.
https://www.corvetteforum.com/forums...placement.html
http://https://www.corvetteforum.com...placement.html
Old May 8, 2018 | 08:37 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
I replaced my window regulator and did not have to purchase a special connector. https://www.ebay.com/i/132427066362?chn=ps
DIY:
I recommend purchasing extra door panel clips.
Old May 8, 2018 | 10:36 PM
Moved to C5 Tech.
Old May 9, 2018 | 01:38 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I just replaced my driver side on my "01 this weekend...Got the AC Delco and no special connector needed !!...plug and play !!...Yeah, mine was making some real grinding noises...works smooth now !!
Old May 15, 2018 | 11:30 PM
VetteC6Dan's Avatar
VetteC6Dan
OK so I need some help... I am sure this is extremely basic for most everyone.
I have the old regulator out, new one in. Also mine did require the new connector which I had to splice together.
anyways I have the window back in but can not get it lined up properly. Can someone tell me what I am doing wrong and explain what the black line is on the bottom right side of the window is for? I am sure it is a guide but I can’t figure out where it is supposed to go to make the window line up?
My process to this point has been loosening the bolt and moving the window up/down/left/right and retightening. I’m sure there is a better way? Again I’m sure this is basic for many, this newbie appreciates the help.
Old May 16, 2018 | 07:58 AM
VetteC6Dan's Avatar
VetteC6Dan
Also I noticed that the left part of the window is not resting flush with the weather strip on the outside of the door where as the rear is? I am guessing there is something in this process I am missing?
To Window Regulator
