Engine oil cooling kit questions
I am looking for an engine oil cooling kit for my supercharged 408 C5. The oil gets very hot at highway speeds on hot days. I very often see temps in the 240-250 range cruising at 85 mph which makes me slow down or get out of the highway.
I sent an e-mail to Lingenfelter about their kit but got no answer. The problem with their kit (for my application) is that I have all the superchager tubing where the radiator is supposed to be mounted. I also contacted PFADT (they used to make a great kit, exactly what I am looking for) but they do not offer it anymore.
I would really like to get a kit that would fit in the front bumper with long enough lines already supplied so I don't have to modify anything over here. Is there anyone who could advise me on who I can contact ? Please do not hesitate to give me your suggestions.
Thanks a lot in advance
No one makes a complete "kit" for what you want, you have to fab it up.
Where is your coolant temp when the oil gets to 250?
What oil are you running?
Coolant gets up to 230. I believe that if I stayed at that speed longer, the temps would keep increasing.
I am running full synthetic castrol or mobile 1 5W40.
I don't have the front bumber cover anymore (the front plate is just under it). By removing it, it helped a little but the temps I am talking about are already without it.
I will contact improved racing and try to fab a kit.
I live in France and getting parts over here gets very expensive when you add shipping + taxes and customs so the goal is to make my car as reliable as I can to prevent avoidable failures. Imroving cooling can only help I guess
http://dougrippie.com/products/stand...il-cooler-kit/
I believe it is mounted in front of the radiator and air conditioner condenser.
I sent an e-mail to improved Racing and I will also contact dougrippie. I will post again on this thread once I know which route I decide to go.
Thanks again for your help guys !
I bought all of my components from Improved Racing. Block adapter with thermostat, Setrab 625 cooler, 10AN braided lines, 90* AN fittings, Raceflux heat sheathing to cover the braided lines. And then I fabricated a basic oil cooler mount from sheet metal that attaches to the radiator frame support in front of the radiator and condenser.
And as mentioned, make sure your radiator/condenser aren't clogged up with debris. If you ended up upgrading the radiator, I recommend the Dewitts aluminum unit. It is thicker than the stock radiator, so if you mount your oil cooler like I did, install the radiator first, then fabricate the oil cooler mount.
Here's how I did my oil cooler. Might give you some ideas.
Thanks for your tips bigmackloud
I should be able to get the car on a lift on saturday. I will take some measurements and see where I could fit the cooler. I already got a reply from improved racing. They should be able to help me gather the right parts for this installation. I will keep the thread updated, it may be useful for someone else in the future!
your oil temps will follow.
I think the real solution to both issues would be a Dewitts radiator.. They even
make a cut down version for Supercharger Apps..
If you get that coolant back down to 200-210 , Your oil temps will drop down
at least 20* degrees.. That bigger cube motor & SC WILL need more cooling system that
the stock can provide
IMO, the plate-cover (& cooler that will fit) is a bit small and airflow is limited - stalling at 40mph, then flowing backwards (unless you have large hood vents etc to reduce under-hood pressure).
The Setrab 625 or bigger 925 you can buy in France with no problem. It's made in Sweden! - no need to ship it around the world
Buy the Setrab and place it in front of the radiator. Then messure the #10 lines you need to the block above the oil-filter and have Improved make them with AN10 fittings. Put it all together and stay cool
