Help with MSD wire set
Old Oct 18, 2002 | 12:36 AM
newberd's Avatar
newberd
Default Help with MSD wire set
Anybody solve the problem with plug wires touching the header pipe for number 4 & 5 cyclinders? Or a suggestion. I had heard of the problem last year and made sure they didn't touch by turning the 90 degree boot at the coil in such a way as to pull the plug end away from the header. I checked them every so often & thought the problem was solved. I stopped checking after several months. The boot on the plug end makes direct & continuous contact with the header pipe and dries out the silicone and then the insulation of the wire itself cracked right where the boot & the wire meet. This in turned caused a bad misfire. I put 2 stock wires on waiting for replacement MSD's to arrive. The MSD's maybe 1/4" to 1/2" too long. May have to go to universal and cut them to fit. And then again with a new set coming just replace as necessary. :confused:
Old Oct 18, 2002 | 02:24 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Help with MSD wire set (newberd)
ya.. change to taylors, the boots dont rub then. I had to swap my MSD's for taylors for the same problem.
Old Oct 18, 2002 | 08:14 AM
Patches's Avatar
Patches
Default Re: Help with MSD wire set (ICULUKN-C5)
:yesnod: What he said. I went with the Taylor Thundervolts and Taylor Fire Sleeves from thunderracing.com No problems here.
:cheers:
Old Oct 18, 2002 | 09:59 AM
nevrenuf's Avatar
nevrenuf
LS1Edit Guru
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Help with MSD wire set (Patches)
CRAP! does this problem exist with brand new MSD sets? I just ordered a set, next day air, to install today.. If I'm gonna have an issue, I may as not install the MSD's and go with the Taylors...
Does anyone have a picture of the taylors, with the sleeves???
Old Oct 18, 2002 | 10:31 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Default Re: Help with MSD wire set (nevrenuf)
Old Oct 18, 2002 | 10:39 AM
Patches's Avatar
Patches
Here you go, Tom. Taylor Thundervolts with Fire Sleeves. Fire Sleeves are rated to 1200 deg. F. I was running Magnecors when I initially put on my headers. The Magnecors are shaped just like the stockers and a few of the spark plug boots were touching the headers so I ordered the Taylor 10.4mm wires. Many here have commented that they've had no problems running these and other wires but I opted for peace-of-mind. :)
:cheers:
[Modified by Patches, 9:41 AM 10/18/2002]
Old Oct 18, 2002 | 11:06 AM
Fahtrim's Avatar
Fahtrim
Taylor's it is then. Thanks!
Old Oct 18, 2002 | 11:13 AM
newberd's Avatar
newberd
Thanks for the info. I think I'll go out to Thunder Racing and see if I get the Fire Sleeves seperately and put them on the MSDs since I have a replacement set on the way. :cheers:
Old Oct 18, 2002 | 12:17 PM
carpe dm's Avatar
carpe dm
I have "Fire Sleeves" too, and have not had a problem. :yesnod: :)
To Help with MSD wire set
