'03 Memory Seat Issue - could use a little help here.
Old May 13, 2018 | 10:58 AM
Deluxe's Avatar
Deluxe
St. Jude Donor '06 thru '16,'22,'24
Default '03 Memory Seat Issue - could use a little help here.
No driver's seat movement except the air supports (lumbar... etc). Also the steering wheel adjustment is not working.
Thought it might be a cold solder joint so I touched up the module under the seat with no change. I then bought a used module since I can't buy a new one. Same results.
Could it be a wire problem or fuse? Where to look next?
Old May 14, 2018 | 07:28 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i would definitely check the fuses do you have anything that says where the fuses are like an owners manual or shop manual?
the fuse panels is under the foot board on the passenger side and in the engine compartment.
if the lumbar support works it makes me think you have power to the seat though
