About a cam
Old May 14, 2018 | 09:59 PM
Herbie67's Avatar
Herbie67
1st Gear
Default About a cam
hi a friend asked if 1.8 roller rockers will work with a stage 3 brain tooley cam? I figured I would post and ask.
Old May 14, 2018 | 10:15 PM
foggy's Avatar
foggy
Depends on the heads, valve springs..
The 1.8 just bring the lobe lift up about .030 ..
So , springs will have to be good enough for the cams lift plus the extra.
Also, Piston to Valve Clearance should be given attention.
