Need help with engine code.....
Old Oct 18, 2002 | 01:51 PM
169mph's Avatar
169mph
Default Need help with engine code.....
My car is throwing a secondary air injection system malfunction code - P0410. Does anyone know what that code means?
Thanks Mike
Old Oct 18, 2002 | 02:32 PM
QwikSilvr's Avatar
QwikSilvr
Default Re: Need help with engine code..... (169mph)
P0410 AIR System-B
I don't have my service manuals in front of me so I'm not sure what the cause or the fix is. I'm someone here will chime in shortly and get you more data....
Frank
Old Oct 18, 2002 | 04:19 PM
SFVetteman's Avatar
SFVetteman
P0410 indicates that the AIR system is not working properly. This code can set as current (c) or history (h). If it is a history code, it might be an intermittent problem. If so, try a reset and see if it comes back.
Are P0412 or P0418 set as well? This might indicate a problem with the AIR pump relay.
If P0410 is current and P0410 and P0418 are not set the first things to check are the AIR pump fuse and blockage/restriction in a hose or pipe before the systems divides.
Post back when you have more info and we'll take it from there.
To Need help with engine code.....
