Display gone out on temperature control screen
Old May 19, 2018 | 04:17 PM
rfh928's Avatar
rfh928
Default Display gone out on temperature control screen
Hi...the display on the temperature control screen of my 98 C5 has been dim for some time and now has gone totally blank. So I can't see what temp I'm setting the a/c or heating at, nor the fan speed & outside temperature.
I did a search online, and someone had posted a detailed procedure on taking it apart, but it involved some fine soldering on the circuit board which I don't trust myself to do. Just wondering if anyone else has encountered this issue and what you've done to resolve it?
Thanks in advance for your advice!
Robert
Old May 19, 2018 | 04:26 PM
redzg's Avatar
redzg
It's like item 2 on the 5,431 known issues list. If check again tonight after dark you'll find it's ever so slightly still there. You can bring the temp display back by re-soldering 8 reisisters, or for a very reasonable sum you can have the resisters resoldered and all the lamps replaced, multiple sources for the repair, but Dave's Corvette Illumination at http://c5led.com/ get's many good reviews. If you really want to do it yourself:
https://www.corvetteforum.com/forums...splay-fix.html
Old May 19, 2018 | 04:53 PM
Smoken1's Avatar
Smoken1
It is an easy repair if you can do it yourself
Old May 19, 2018 | 04:56 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
had 2 fixed back in the day...2 day turnaround less than $50 each...if you know someone who can solder...show them the tutorial, buy them lunch
Old May 19, 2018 | 06:02 PM
pewter99's Avatar
pewter99
Originally Posted by 8VETTE7
Or check a local PC repair shop or TV repair place. They commonly solder on temp sensitive boards and will likely do the deed for a very reasonable price....... Bring them the tutorial and it is a 5 minute job.........
One Forum member just had the early year FOB soldered for about $20 at a local PC repair place......
good point there are lots of those U Break I Fix places that fix cell phones that may be an option
Old May 19, 2018 | 10:48 PM
FASTOYZ's Avatar
FASTOYZ
I just resoldered mine last week as it was getting pretty dim & I'm about to take it on a road trip. It wasn't a bad job at all to remove it even if you prefer to have someone else do the soldering.
Old May 19, 2018 | 10:58 PM
ZERRY 316's Avatar
ZERRY 316
or its a hard repair if you cant do it yourself
Old May 20, 2018 | 08:06 PM
TorqueWinsRaces's Avatar
TorqueWinsRaces
I had Dave's Corvette Illuminations fix mine. I also had him customize the colors. Couldn't be happier.
To Display gone out on temperature control screen
