Brake Low Fluid Level in DIC on startup
Old 05-21-2018, 03:26 PM
FOGeologist
FOGeologist's Avatar
Default Brake Low Fluid Level in DIC on startup
My '97 is occasionally flashing a "Brake Low Fluid Level" warning in the DIC on startup. Guess it did it to the used car dealer; he replaced the sensor. The actual fluid levels are fine, and the brakes will happily put you through the windshield. Dealer also replaced the rotors and pads up front; the message was appearing before the brake job.
Did it the afternoon I picked the car up and it's been giving me the warning over the last few days.
Ideas? Thinking I may pursue the ground issue this weekend, as school will be done for the summer, although I doubt it's gone bad as the Colorado air is very dry and virtually nothing corrodes here.
Quick Reply: Brake Low Fluid Level in DIC on startup
