Shock Install Question
Old May 25, 2018 | 06:51 PM
BarneyZ's Avatar
BarneyZ
Default Shock Install Question
Getting ready to change shocks on my '02 coupe.Can I "loosen", without uninstalling, the two reservoir tanks enough to clear the Lisle Tool on the front ends?
Thanks!
Barney
Old May 25, 2018 | 08:16 PM
StingrayRebel's Avatar
StingrayRebel
what tool are you referring to?... you should be able to remove the 10mm nuts holding each tank down and move it out of the way enough (without disconnecting anything) to get a socket on the upper shock nut, that's what I have always done
Old May 25, 2018 | 10:01 PM
NCVette1's Avatar
NCVette1
I watched the guy install my Z06 shocks a few weeks back. All he did was unbolt it and slide it over. Didn't take him 5 minutes to do both sides and nothing was disconnected.
Old May 25, 2018 | 10:43 PM
BarneyZ's Avatar
BarneyZ
Here's the tool on AMZ:
Amazon Amazon
The idea is that you can grip both the stem and the bolt at the same time, holding one still and turning the other. They work pretty well, as long as you have room. Changed shocks on my C6Z using it. You guys answered my question though. Looks like I could use a ratcheting wrench if worse comes to shove.
Thanks!
Barney
Old May 26, 2018 | 08:08 AM
bravo29's Avatar
bravo29
Yes you can on both. You can loosen both and just hold it out of the way while you loosen the bolts with the lisle tool.
To Shock Install Question
