Car did something weird last night
Old May 27, 2018 | 01:56 PM
UM Rebel's Avatar
UM Rebel
Default Car did something weird last night
2004 CE convertible
I went to the grocery store yesterday evening. I was going to put everything in the trunk. Pressed the trunk button on key fob. Nothing happened. Pressed a few more times still nothing. Pressed the unlock button. Doors unlocked. Opened driver's door and the alarm went off. Pressing unlock would not stop the alarm. Started car. Alarm stopped. Now everything is working fine.
Have 2 codes
U1255 Serial Data Line malfunction
B2860 Telescoping Column Position Sensor Failure
Both history
Any ideas about what would cause this or if I should be concerned.
Old May 27, 2018 | 03:43 PM
calguy's Avatar
calguy
Originally Posted by UM Rebel
2004 CE convertible
Have 2 codes
Both history
Put a new battery in your key fob.
Bob.
Old May 27, 2018 | 05:17 PM
UM Rebel's Avatar
UM Rebel
Ha! You are probably correct. Didn't think of that. Both fobs still have original batteries from when I bought it new in 2004.
Old May 27, 2018 | 10:49 PM
Moved to C5 Tech.
And please post up if the battery replacement solves the problem.
Old May 27, 2018 | 11:55 PM
FX VETTE's Avatar
FX VETTE
Old May 28, 2018 | 12:04 AM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
14 year old car gremlins !!
Old May 28, 2018 | 03:23 PM
UM Rebel's Avatar
UM Rebel
Replaced batteries in fobs. Cleared codes. Problem has not recurred. Fobs have much better range now. Thanks for the advise.
Old May 28, 2018 | 03:24 PM
UM Rebel's Avatar
UM Rebel
Originally Posted by 8VETTE7
Which sensor was the U1255 code under?? ie 10 - PCM or 28 - TCS or 40 - BCM .... etc ....
I would clear the codes and see what if any come back...........
Both codes were under SCM.
To Car did something weird last night
