HELP!! Front Headlight lifts... bronze
Old May 28, 2018 | 08:58 PM
tipteman's Avatar
tipteman
1st Gear
Default HELP!! Front Headlight lifts... bronze
Hi... we have a 1999 C5 Coupe... curious if its worth spending the extra money for a bronze geared refurbished headlamp lifter.... ??? the car is rarely driven and we want to do the correct thing... please advise
Old May 28, 2018 | 09:54 PM
JR-01's Avatar
JR-01
You can get a remanufactured complete motor assembly for about 90 bucks. If mine ever fails that is what I will do.
Old May 29, 2018 | 01:14 AM
GCG's Avatar
GCG
Is the headlight motor broken, or are you buying a spare one?
There are 2 type of headlight motors. The one that was factory installed from "1997 to early 2000" and the one from "late 2000 to 2004" (although they are interchangeable):
  • The 97 to early 2000 motor assembly is all aluminum and has a removable side cover that is held on with 3 machine screws.
  • The late 2000 to 2004 headlight motor assemblies are plastic and the side cover is glued on.
If the plastic gear failed in your 1999, replacing it with a brass one is very easy. It's a matter of just removing 3 screws, replacing the gear and internal rubber isolator, and screwing back the cover. You can save some money going this way and you'll know it was properly done
Old May 29, 2018 | 10:00 AM
joezr2's Avatar
joezr2
If even for research this should help: http://rodneydickman.com/catalog/pro...products_id=92
I bought the kit to replace and it turned out the pin just fell out of the arm. I replaced the pin but I have rodney's kit ready when needed.
Old May 29, 2018 | 10:09 AM
Moved to C5 Tech.
To HELP!! Front Headlight lifts... bronze
