Break drag. Need help. Can not drivable!!
Old May 30, 2018 | 10:48 PM
Mjk85's Avatar
Mjk85
Default Break drag. Need help. Can not drivable!!
2001 Corvette C5 57,000 miles on it second owner always serviced on time from the day about the car at the brakes felt weird to get back to you dealer several times they attempted to fix it said it was good I drove the car for a couple more thousand miles and it progressively got worse to where the front brakes would drag and start smoking I can lift my foot underneath the pedal sometimes and live the break towards me it helps to disengage the brakes a little bit but they always robe any help would be greatly appreciated I have taken it to three different Chevrolet dealerships 2001 Corvette C5 57,000 miles on it second owner always serviced on time from the day about the car the brakes felt weird to get back to you dealer several times they attempted to fix it said it was good I drove the car for a couple more thousand miles it progressively got worse to where the front brakes with dragon start smoking I can lift my foot underneath the pedal sometimes and live the break towards me it helps to disengage the brakes a little bit but they always robe any help would be greatly appreciated I have taken it to three different Chevrolet dealerships no one Able to diagnose the issue I have replace the master cylinder front brake calipers brake rotors and pads as well as ABS modulating valve for the dealerships request/diagnosis
Old May 31, 2018 | 02:22 AM
Moved to C5 Tech.
Old May 31, 2018 | 08:20 AM
runner140*'s Avatar
runner140*
I know I am very old, now.
Old May 31, 2018 | 09:57 AM
TorqueWinsRaces's Avatar
TorqueWinsRaces
There is a key that is two spaces to the right of the "M". It looks like a little dot. We call that dot a "period" and we use it to delineate sentences, which makes it easier to read the written word. Try it sometime!
Old May 31, 2018 | 10:09 AM
8VETTE7's Avatar
8VETTE7
Old May 31, 2018 | 10:17 AM
chris308's Avatar
chris308
Why start another thread of the same thing. You were given some suggestions to try in the other post you made.
Old May 31, 2018 | 10:26 AM
GCG's Avatar
GCG
He posted similar threads in both, General and Tech. The one from General got moved to Tech and now it's like one of those mystical animals with 2 heads . Perhaps it might be a good idea if they could be merged into one.
Old May 31, 2018 | 10:34 AM
jvettman's Avatar
jvettman
Right! Is this what that new thing called "Texting" looks like? Very hard to read...
runner140*'s Avatar
runner140*
Thanks, thought it was just me.
Old May 31, 2018 | 11:52 AM
GCG's Avatar
GCG
Very true and, on top of that, it seems that a big block of "text" was entered twice. It goes from the beginning to almost the middle of the post, and then it goes again with some variations, finally adding a few more lines to close it. I had a hard time trying to make sense out of it as well and hallucinations going through the duplicated thread
Old May 31, 2018 | 11:53 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
ok, well now that all the English teachers have chimed in.......
To Break drag. Need help. Can not drivable!!
