roller rocker clearacing
Old Jun 2, 2018 | 08:24 AM
frc00ny's Avatar
frc00ny
Default roller rocker clearacing
I am installing Harland Sharp roller rocker on my stock LS1 heads.
One head there was room, but very little. the other head I had to grind material away to make room.
My concern is how much room do I need?
do the rockers move or deflect under load?
will they expand or get bigger with heat?
The head was already clearance by the factory. even more so on the side I am having to clearance.
Kevin
Old Jun 2, 2018 | 09:37 AM
Frank O'Brien's Avatar
Frank O'Brien
2 cents, I'd say .030 .
Old Jun 2, 2018 | 12:30 PM
heavymetals's Avatar
heavymetals
You can get shims for the valve covers from JEGS.
I had to go that route even after I removed all the bosses an baffles from the valve cover.
I have a set for sale.
https://www.jegs.com/i/PRW/228/41346...EaAg3OEALw_wcB
To roller rocker clearacing
