Electrical
Old Jun 2, 2018 | 10:47 PM
Dallasfool's Avatar
Dallasfool
Default Electrical
Air conditioner started blowing out hot air, turn signals blicking real fast, only back tail lights are working, when turn signals are turned on, no front signals, headlights will not pop up, radio center console lights not working, after car is turned off, clicking sound coming from passenger side of the vehicle, ( engine bay area), all this started after going over railroad tracks, at a very slow speed? When turn signals are turned on to the left or right, both lights on the one side are blinking
Old Jun 4, 2018 | 03:41 PM
Robrote's Avatar
Robrote
It it were me, I would start by cleaning the two ground blocks on the frame rails in the engine compartment. They come apart for easy cleaning. It's common to have ground issues with these cars. When you think you have everything cleaned, clean them some more. I ended up running a second ground strap from the ground block to the hood hinge for a better ground.
You may also have a Hazzard switch bad. They are easily replaced or you can by a bypass mod for it. Plenty of links on here and on youtube for both. I'd start with the grounds.
Old Jun 4, 2018 | 07:57 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yes, grounding is the issue. Try pulling the battery cables, cleaning them and reseating properly. You also get the benefit of a "hard boot" of the computer.
Old Jun 5, 2018 | 07:01 AM
Dallasfool's Avatar
Dallasfool
I disconnected battery, and let it sit over night, next morning, went ahead and cleaned them two grounding areas as mention ,but were not really dirty only have 15,600 miles on it, I reconnected battery, did not hear any clicking sound coming for engine bay area, did the error code found 7, reset them, started it back up, and everything seems to be running fine for the last 2 days, appreciate every ones help!
To Electrical
