rim size
Old Jun 3, 2018 | 09:26 AM
Rookie C5 Owner's Avatar
Rookie C5 Owner
Navigator
Default rim size
Good morning, want to install c6 original factory rims on my c5. I know the size is 17 and 18 for the c5
Old Jun 3, 2018 | 10:33 AM
Rookie C5 Owner
Navigator
Originally Posted by 8VETTE7
Been covered a million times.........
Fronts fit with no problems. rears will be sunk into the rear wheel wells a significant amount. If you like tht look you are golden. If you want the rear wheels to come flush to the rear fenders you will need a 1" wheel adapter. This is for base C6 wheels and NOT for the C6 Z06 or C6 Grandsport wheels.
Thank you for the quick response. If I utilize the 1 inch spacers, should I install longer wheel studs?
Old Jun 3, 2018 | 02:05 PM
Rookie C5 Owner
Navigator
Get a wheel adapter and NOT spacers. Spacers would require longer studs and those are a royal PIA to install on the back of a C5.
This is what a wheel adapter is:
http://www.ezaccessory.com/Billet_Wh...f5djq999gnahcr
For a C5 you need a 1" thick 5 stud on 4.75" to 5 stud on 4.75" adapter.
Thanks again for the guidance. Thank you for the link as well.
To rim size
