Rear bumping noise
Old Jun 3, 2018 | 12:59 PM
Grandy's C5's Avatar
Grandy's C5
3rd Gear
Default Rear bumping noise
'04 LS1, every morning that I take it out, 100 feet out of the driveway, I hear a bump from the right rear. Was told that it's the ABS recalibrating. Is that right?
Grandy
Old Jun 3, 2018 | 02:08 PM
Smoken1's Avatar
Smoken1
No, on a 04 the ABS unit is the front
Old Jun 3, 2018 | 02:10 PM
DaleInColorado's Avatar
DaleInColorado
Default Me too on rear bumping noise - C5
I have had my C5 up in the air 3 times with techs who found nothing loose. Bump comes from right rear. I hope someone knows something about this.
Grandy
Old Jun 3, 2018 | 02:20 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Check your sway bar end links for missing or worn out boots.
Old Jun 3, 2018 | 03:11 PM
Moved to C5 Tech.
Old Jun 3, 2018 | 03:43 PM
Grandy's C5
3rd Gear
Moved to C5 Tech.
This only happens in the morning when I leave, exactly 100 feet down my street, same spot every day, and not again until the next time I take it out.
Grandy
Old Jun 6, 2018 | 12:17 AM
striper's Avatar
striper
Try this. Loosen and remove the nut on the axle on the right rear. Move axle slightly inward and regrease the splines on the axle stub that go into the hub carrier. Re install and torque the axle nut back to specs. Good chance this will fix it, had been a common problem for a while.
Old Jun 6, 2018 | 09:47 AM
seattle's Avatar
seattle
Old Nov 24, 2019 | 09:37 PM
Rick369's Avatar
Rick369
Grandy
I have the same exact issue on my 2004 A4 Vert. It just started doing this. Were your axle nuts loose and was this the problem?
Old Nov 25, 2019 | 03:04 PM
Chillo32's Avatar
Chillo32
Rear clunking is a common issue. Do a search. There are hundreds of threads on this. Could be a dozen different issues.
Old Nov 25, 2019 | 04:39 PM
Rick369's Avatar
Rick369
I know that. That’s why I did a search and directed my question to Grandy’s C5.
Old Nov 25, 2019 | 04:42 PM
Chillo32's Avatar
Chillo32
Wasn’t talking to you. Lol.
To Rear bumping noise
