Rocker arm pedestal orientation
Old Jun 3, 2018 | 03:36 PM
trflach's Avatar
trflach
Default Rocker arm pedestal orientation
Hi, I'm currently doing valve springs and seals on my 03. For reinstalling the rocker arms, does it matter which orientation the spacer/pedestal is put back in? It's the long spacer that the rockers sit on. It looks symmetrical but I can't tell if it matters (words facing up or down ).
Old Jun 3, 2018 | 04:28 PM
jvettman's Avatar
jvettman
I believe it does matter, I believe you should be able to read the words (as in they should not be upside down). These are things I believe...and I may be wrong.
Having said that...all the FSM says is "Install the valve rocker arm pivot support." It does mention installing the components "to the original location and position"...which kind of introduces a little gray area.
Old Jun 3, 2018 | 10:11 PM
Georgies's Avatar
Georgies
I also read that it.does not matter. So i installed mine reading right.
To Rocker arm pedestal orientation
