HELP!!
Old Oct 19, 2002 | 05:50 PM
skidmarc's Avatar
skidmarc
Default HELP!!
Hi Guys I just changed my battery to a AC DELCO AGM and my keyless entry will not work...and my radio is locked...I read tech tips on radio but whats goin on with keyless entry?????
Thanks for any advice guys
Marc
Old Oct 19, 2002 | 05:59 PM
soapy's Avatar
soapy
Default Re: HELP!! (skidmarc)
You need to hold lock and unlock down on the fob for about 10 seconds. If you hear the horn honk you should be good. If not there is a more extensive procedure in your owners manual which you do through your DIC (digital information center) and is a complete reprogram that will work for any fob including a new one.
Good Luck
Old Oct 19, 2002 | 06:07 PM
skidmarc's Avatar
skidmarc
Default Re: HELP!! (soapy)
It worked...thank you very much.... :seeya
To HELP!!
