Antifreeze leak
Old Jun 10, 2018 | 04:14 PM
LQQK's Avatar
LQQK
Default Antifreeze leak
I seem to have a antifreeze leak on the right side of the motor. I can't seem to find it. Of course you can't see anything from the bottom. Anyone ever have this problem before? Or have an idea where to look?
Old Jun 10, 2018 | 04:36 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I'd check heater hoses first.
Old Jun 10, 2018 | 04:52 PM
seattle's Avatar
seattle
Check the fittings at the bottom of the surge tank. The plastic tank can crack over time.
Old Jun 10, 2018 | 05:07 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
This is the way to bet.
Old Jun 10, 2018 | 08:52 PM
LQQK's Avatar
LQQK
Found it and your right. The surge tank is the culprit. I will check Amazon..Thanks..
Old Jun 10, 2018 | 09:03 PM
Arvalo's Avatar
Arvalo
Agreed with the above. I have this problem as well, my surge tank has the tiniest crack in it on the top side nipple right where it meets with the tank. It’s right where the hose stops. You can’t even see it unless you wiggle the hose slightly.
i think I’m just gonna spring for the aluminum replacement tank and spare myself the fear of a repeat.
Old Jun 10, 2018 | 09:42 PM
Moved to C5 Tech.
Old Jun 18, 2018 | 03:56 PM
huesmann's Avatar
huesmann
You can probably get the same Dorman tank from Rock Auto for less than it is on Amazon.
To Antifreeze leak
