Outside temp reading a bit high!!!
Old Jun 11, 2018 | 02:32 PM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
Default Outside temp reading a bit high!!!
I am having an issue with my ambient temperature readings.
They are about 6-10 degrees higher than what they actually should be.
Actual temperature is always less.
I bought and installed a new probe sensor and that didn't fix it. What else could it be ?
Old Jun 11, 2018 | 06:29 PM
knewblewkorvette's Avatar
knewblewkorvette
I would think the only thing that could cause this is the temp sensor which you already replaced. I did have the problem on my 98 and replacing sensor fixed it.
I wish there was a way to adjust the settings like my 99's ave. fuel mileage as it is way off.
Old Jun 11, 2018 | 11:30 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
I thought you could adjust the temperature "reading" some how ....did I maybe read that in one of my other cars?
Old Jun 12, 2018 | 04:01 AM
corvettezman
None that I know of.
Old Jun 12, 2018 | 04:30 PM
bobs77vet's Avatar
bobs77vet
I must have been thinking about my newer minivan, I know I had to do it in that.
Old Jun 17, 2018 | 05:50 PM
corvettezman
I was working on my radio installing new peripherals, I unplugged the AC unit and moved it somewhere safe. When I got done putting everything back together about an hour later, the reading on the AC unit once reconnected pegged at 106F.
A short drive around the block and the outside temp has been reading the correct temp ever since.
I guess the AC head unit had to be unplugged and reset. So far, problem is solved for now.
To Outside temp reading a bit high!!!
