Can't remove anti-theft valve stem caps
Old Jun 11, 2018 | 03:13 PM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Default Can't remove anti-theft valve stem caps
Bought a C5Z a year ago, and need to fill air in the tires. Problem is I can't remove the aftermarket valve stem caps, they just spin when I try to remove them. There's no pin or anything like traditional anti-theft caps. I did some digging and it looks like the following:
Amazon Amazon
However I don't have that tool that they come with. Any alternative method to get these things off? Or if anyone has a spare tool they could send I'd pay postage!
Old Jun 11, 2018 | 03:32 PM
jrprich's Avatar
jrprich
I would contact vendors that sell these for help.
https://www.mamotorworks.com/corvett...alve-stem-caps
http://www.westcoastcorvette.com/c-2...stem-caps.aspx
http://corvettespecialty.com/corvett...s-with-c5-logo
Old Jun 11, 2018 | 03:34 PM
bluewire's Avatar
bluewire
Active Streak: 90 Days
Maybe some light pressure with a pair of pliers.
Old Jun 11, 2018 | 06:55 PM
StingrayRebel's Avatar
StingrayRebel
you just need to keep the valve stem from turning, likely whoever put them on last tightened them too much... hold the stem with one hand and loosen with the other
Old Jun 13, 2018 | 06:38 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
I would think any tire shop or garage would be able to help you.
Old Jun 13, 2018 | 06:43 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
thats what it sounds like, just need to apply pressure to squeeze the cap
Old Jun 14, 2018 | 12:12 AM
KOZ's Avatar
KOZ
Its a valve stem cap....how complicated can it possibly be??
Old Jun 14, 2018 | 11:45 AM
GCG's Avatar
GCG
Originally Posted by ArmchairArchitect
...I can't remove the aftermarket valve stem caps, they just spin when I try to remove them. There's no pin or anything like traditional anti-theft caps. I did some digging and it looks like the following:
Corvette-Black-Theft-Deterrent-Z06-Valve-Caps
However I don't have that tool that they come with. Any alternative method to get these things off?...
They are doing what they are supposed to do
If you don't have the tool they came with, perhaps you could try to find the manufacturer to buy one, but in the mean time don't try to use pliers or pressure unless you want to destroy them
Right at the base of the cap there is a thin plastic lip (black) with 4 flat sides forming a square. This is the lip the removing tool grasps in order to install and remove the caps.
Get a 5/16 mini ignition wrench. Make sure its thickness is no more than 3/32, like the one in the 1st picture I'm attaching here.
Insert the mini wrench right at the base of the cap (see my 2nd picture) carefully going around until you correctly align it with the flat sides of the plastic lip and then unscrew it.
I hope my message is reaching you on time! Godspeed!
To Can't remove anti-theft valve stem caps
