Does anybody know...
Old Oct 19, 2002 | 10:51 PM
Villain's Avatar
Villain
Default Does anybody know...
What is the true top speed of a stock C5 hardtop, M6, non-Z06, that has been chipped? I have a guy at work who is giving me fits about the top speed. I know about the GM set 175 mph. What if there was no chip setting?
Old Oct 19, 2002 | 11:14 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Default Re: Does anybody know... (Villain)
There is NO speed limiter or "chip setting" in the C5.
Speed Limiters in nearly all cases around the world, are implemented for the sole purpose of the tires speed rating on the vehcile used. The tires on the C5 exceed the C5's Top speed ability, thus there is no limiter.
The hardtop is about .31 in drag coefficient, and the coupe is about .29
They are both wind drag limited in thier top speed in fifth gear.
[Modified by kewlbrz, 9:15 PM 10/19/2002]
Old Oct 20, 2002 | 12:19 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Does anybody know... (kewlbrz)
with 3:42 gears in 5th gear at 6200 RPM, your top speed should be in the 187 range. However that does not take into effect wind, or rolling resistance.
I can tell you from personal experience, that I had a hard time getting over 179 in my coupe, but that was before I lowered it and put N20. I also had my rev limiter raised, since I have a 02' LS6 motor in my car now.
Old Oct 25, 2002 | 09:53 PM
Villain's Avatar
Villain
Thanks fellas. Sorry it took me so long to thank you for your input. I've been out of the loop for a bit and haven't checked this section of the forum. This info should be sufficient to quiet the masses. As far as not having a chip limiter, I thought I saw somewhere, don't ask me where, that you could get a "piggy-back chip" to eliminate the limiter. Was that bogus information?:cheers:
[Modified by Villain, 1:55 AM 10/26/2002]
Old Oct 25, 2002 | 11:19 PM
Mark V's Avatar
Mark V
It was bogus info. :yesnod: Quite a few members have reported going over 175 with no problems. :eek:
Old Oct 26, 2002 | 10:18 PM
Villain's Avatar
Villain
Default Re: Does anybody know... (Mark V)
Thanks. BTW, Racer X, are you my brother? (Thwack) :lol:
Old Oct 28, 2002 | 02:43 PM
scool93535's Avatar
scool93535
Default Re: Does anybody know... (ICULUKN-C5)
Would you think based on my sig numbers, I would have a shot at cracking 180? Given ideal wind and weather conditions of course. :cheers:
To Does anybody know...
