2001 C5 Corvette water leak
Old Jun 11, 2018 | 11:51 PM
C5Corvette95's Avatar
C5Corvette95
7th Gear
Default 2001 C5 Corvette water leak
Hello everyone, new to the forum so I hope this is in the right spot.
I just purchased a C5 Corvette and its been running great. However, after turning the car off I noticed a puddle of fluids on the floor under the car. I looked under the car and it seems to be coming from under the passenger side but somewhat closer to the middle of the car. It's definitely water and not oil though. Any idea of what this would be? I looked around and some possibilities I could come up with is either some water pump leak or something with the A/C? I could be off though. Any advice would be appreciated.
On a side note, I am not super mechanically inclined. I can change oil and tires and do fluids but that's about it. I am located in South Bend, Indiana. Does anyone know any trusted/good mechanics for corvettes within a 50 mile radius of Notre Dame?
Old Jun 12, 2018 | 04:07 PM
C5Corvette95
7th Gear
Originally Posted by 8VETTE7
If it is water and not coolant (anti freeze) and it is the middle of the car i would suspect the AC condenser pan drain. That is located on the bottom of the firewall just a bit to the passenger side of the car side to side.
If it is coolant then the most likely thing would be a leak in the surge tank that travels along engine and/or frame to make its way to the ground.
There are also wiper well drains referred to as udders that could be partially plugged with debris and slowly weep out wash water or rain that gets in the wiper wells. Here is a link about plugged udders and other leaks in the C5:
https://www.corvetteforum.com/forums...ak-checks.html
I felt it and it was cold like water with no smell and the consistency of water. My roommate decided to put his finger in it and taste it and was like "Yup it's water" It did rain hard on the car the other day but it seems to only do it when I use the AC
I would also like to add, after the car turns off its leaks the water then after a few minutes slows to a drip and then stops all together. When the car is off for about 10-15 minutes there is no more leakage
Old Jun 12, 2018 | 05:21 PM
knewblewkorvette's Avatar
knewblewkorvette
Most likely AC condensate...
Old Jun 12, 2018 | 07:04 PM
Simtech's Avatar
Simtech
Living in the south there is a lot of water that drains from the a/c. Gotta love humidity.
Old Jun 12, 2018 | 09:20 PM
01pewtervert's Avatar
01pewtervert
Where is Mr. Obvious when you need him?
To 2001 C5 Corvette water leak
