Fuel door button
Old Jun 12, 2018 | 09:01 PM
RCapece's Avatar
RCapece
Default Fuel door button
Hi
I have a 2002 corvette coupe and the button doesn't work to release my fuel door.I found the manual one in the trunk but i prefer to use the one in the console.When i hit the button it dont even make a noise.Is there a fuse i should look for?If so where is it and what is the name of it.I couldn't find it anywhere
Old Jun 12, 2018 | 10:15 PM
chris308's Avatar
chris308
Google
2nd post
https://www.corvetteforum.com/forums...st-please.html
Old Jun 14, 2018 | 11:12 AM
AntonioZ06's Avatar
AntonioZ06
If it’s not a fuse problem and the actual mechanism it’s a relatively cheap part and fairly simple one to replace. Involves jacking up the rear of the car and removing the rear drivers side inner fender liner and inner trunk wall if my memory is correct. Pretty simple to do. There should be other threads about how to change it.
Old Jun 14, 2018 | 12:35 PM
UM Rebel's Avatar
UM Rebel
Test the button with an ohm meter first. Connect volt meter between the two pins in pigtail should be 12 v. If so, connect the two connectors in the pigtail with a paper clip to see if fuel door pops open.
Old Jun 14, 2018 | 02:24 PM
Moved to C5 Tech.
Old Jun 14, 2018 | 04:43 PM
knewblewkorvette's Avatar
knewblewkorvette
It is the connector on the lower right (between the number 5 and 8)
Just take a wire of some sort and jump the two connectors (of the 5)
To Fuel door button
