torque for c5 lug nuts?
Old Oct 20, 2002 | 08:07 AM
ydeer's Avatar
ydeer
Default torque for c5 lug nuts?
can anyone tell me the torque for the c5 lug nuts??
Old Oct 20, 2002 | 08:24 AM
Tom/99's Avatar
Tom/99
Default Re: torque for c5 lug nuts? (ydeer)
100 foot pounds.
Old Oct 20, 2002 | 10:21 AM
wstory1's Avatar
wstory1
Default Re: torque for c5 lug nuts? (Tom/99)
100 foot pounds.
Old Oct 20, 2002 | 11:27 AM
RoliO's Avatar
RoliO
100 foot pounds.
:smash: :yesnod: :yesnod:
Old Oct 20, 2002 | 11:49 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Do them in 3 phases... 40, 70, 100! Prevents warping of your rotors....
Old Oct 20, 2002 | 11:21 PM
mrkln's Avatar
mrkln
Default Re: torque for c5 lug nuts? (Smoke-N-Shot)
Old Oct 21, 2002 | 11:45 AM
Smokin Joe's Avatar
Smokin Joe
Not to split hairs, but an engineer for the C5 told me 100 ft-lbs. 30-60-90-100 in a star pattern. I don't think it matters. Tightening it sequentially will uniformelly seat the wheel.
Old Oct 21, 2002 | 04:01 PM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
I do three steps. Spin them snug with the lug wrench. Hand tight with torque wrench and then 100 lb with torque wrench.
My wheels are off the car often swapping from street to drags to street and back.
Old Oct 22, 2002 | 02:30 AM
motoracer's Avatar
motoracer
Also after you drive the car for about 10 to 20 miles, retorque the lugs again. This is recommended for non steel wheels.
I have noticed that my lugs "settle" and have to be redone.
Some will turn and some won't. And I know I did it right the first time. I go over each lug at least 2 times sometimes 3 at 100 lbs.
Old Oct 22, 2002 | 02:50 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
When I toured the assembly plant, I could have sworn they put the wheels on then use their calibrated pneumatic impact driver to tighten all of the lugnuts in one step, theres none of this 30 60 90 100 stuff. but whatever makes you comfortable :p:
Old Oct 22, 2002 | 02:55 AM
Sam Lin's Avatar
Sam Lin
Default Re: torque for c5 lug nuts? (runamuk)
It'd be interesting to hook up a test sensor and see how "calibrated" that impact gun is.
There's a reason why people who just drive their cars off the lot sometimes get warped rotors, and people who race and often swap wheels, who take the effort to use a torque wrench and evenly torque in a stepped pattern, have never experienced warped rotors.
I go as far as to take the torque wrench with me if any car visits the dealer and they take the wheel off, so I can back off the lugnuts and retorque them evenly to my values as soon as I get the car back, even before I drive it.
Sam
Old Oct 22, 2002 | 12:38 PM
HOTSOSS's Avatar
HOTSOSS
what about lubrication. this can make a difference, sometimes a big difference in compressive force (wheel against the hub). I would think a light lubrication is necessary to get even torque and force.
Old Oct 22, 2002 | 03:21 PM
motoracer's Avatar
motoracer
Default Re: torque for c5 lug nuts? (BLU PIL)
My tech told me that if I take the wheels off often, then you can put lubricant on the lug bolts, but then only torque to about 80lbs.
Old Oct 22, 2002 | 03:25 PM
skidmarc's Avatar
skidmarc
does it matter if you have the magnesium wheels? I hear they bend easy..... :confused:
Old Oct 22, 2002 | 10:05 PM
Lawdogg's Avatar
Lawdogg
Active Streak: 90 Days
100 is too much. 80 to 85 is plenty.
Old Oct 22, 2002 | 10:41 PM
Bill Dearborn's Avatar
Bill Dearborn
Default Re: torque for c5 lug nuts? (Rippied Z06)
Spec is 100 ft lbs. Anything less you are taking chances. Lubricant screws up the torque reading and you can't adjust for it by dropping 20 lbs since you really have no idea how much to drop.
I change wheels front and rear many times during the racing season. I hold the wheel against the hub with my knee to make sure it is seated properly and then use the air wrench in a star pattern until each lug just hits the wheel. After all the lugs are this tight I go back and use the torque wrench to take them t0 100. Have never warped a rotor in 5 years of owing my C5 and in the 10 years I owned my C4.
Bill
Bill
Old Oct 24, 2002 | 11:56 AM
skidmarc's Avatar
skidmarc
Does the torque setting differ for magnesium wheels?
Old Oct 24, 2002 | 11:58 AM
Sam Lin's Avatar
Sam Lin
Default Re: torque for c5 lug nuts? (skidmarc)
No.
Old Oct 24, 2002 | 12:22 PM
Skyguy^^'s Avatar
Skyguy^^
According to the C5 service manual:
A torque wrench must be used to ensure that wheel nuts are tightened to specification. NEVER USE LUBRICANTS OR PENETRATING FLUIDS ON WHEEL STUD, NUTS, OR MOUNTING SURFACES, AS THIS CAN RAISE THE ACTUAL TORQUE ON THE NUT WITHOUT A CORRESPONDING TORQUE READING ON THE TORQUE WRENCH..... Failure to follow these instructions could result in wheel, nut, and/or stud damage.
IMPORTANT: Tighten the nuts evenly and alternatively in order to avoid excessive runout.
Tighten the nuts in a criss/cross patern to 14 N.m (100 lb ft).
As far as rotor warping?? :confused: Please read this:
http://www.stoptech.com/whitepaper/warped_rotors_myth.htm
To torque for c5 lug nuts?
