93 Octane
Old Jun 15, 2018 | 03:20 PM
gnharley's Avatar
gnharley
Default 93 Octane
I'm going to be installing PRC CNC ported 243heads with 61cc combustion chambers & gaskets to put me at around 11.1:1 Static compression ratio , can anyone tell me if they've run this amount of compression on 93octane unleaded with good/bad results ? Cam is Texas Speed 224R......224/224 duration , .600 lift intake & exhaust 112 lobe separation , thanks in advance to you good People of the Forum !
Old Jun 15, 2018 | 07:00 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
I'm running reasonably similar heads, cam is a little larger, long tubes, A4 with 3.42 and do fine on 93 octane. When I'm home I'm able to get ethanol free fuel.
I've had to run 91 octane on some trips when it was the only fuel available and still did fine.
I've never run anything lower than 91 but know others who have in emergency situations when that was all they could find and the car ran ok. Not as much horsepower as with better fuel due to the PCM retarded timing but it'll still get you home.
Old Jun 15, 2018 | 07:45 PM
gnharley's Avatar
gnharley
Default 93 Octane
Thanks ! Just wanted to hear that from someone with actual time on the road with that compression range , instead of " I guess it should be ok "
Old Jun 15, 2018 | 08:49 PM
Route99's Avatar
Route99
Glad to help out!
Old Jun 18, 2018 | 06:31 AM
quick89's Avatar
quick89
Default Octane
Running 11.6 on 93 with no problems
Old Jun 19, 2018 | 08:12 PM
gnharley's Avatar
gnharley
Default 93 Octane
Thanks Friend , this is what I was hoping to hear !
To 93 Octane
