Steering lock stuck in LOCK, Help Needed
Old Jun 17, 2018 | 08:07 AM
Martyn's Avatar
Martyn
Default Steering lock stuck in LOCK, Help Needed
I just got an 03 Z06 today and the dreaded steering lock is stuck in the LOCK position.
The wait 10 seconds messege comes up as does the service steering lock messege.
I have a Tech II and tested the motor and nothing, you can hear the relay in the BCM sending the info to the lock but its dead,, I have tapped it with a hammer and if I hit it hard enough I can get the weel to turn to the next lock position.
I can easily grind off the lock pin if I have to
What are my options? I would really appreciate any help, in the past I have just installed a bypass as the system has been unlocked on my other vehicles but this one has got me?
I have a spare bypass kit here.
Thanks in advance
Old Jun 17, 2018 | 08:26 AM
redzg's Avatar
redzg
https://www.corvetteforum.com/forums...ky-please.html
http://www.complianceparts.com/lmc5ataglance.html
http://www.complianceparts.com/lmc5unlocker.html
Old Jun 17, 2018 | 09:10 AM
steig's Avatar
steig
LMC5 MODULE is what I used. Cheap and easy to install.
Old Jun 17, 2018 | 09:14 AM
steig's Avatar
steig
Since yours is locked already, you may need the LMC5 Unlocker also.
Thats like an extra 6 bucks.
Old Jun 17, 2018 | 09:26 AM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Hammer?? Dude WTF?
Get the LCM5 as mentioned. 30 minutes of crawling under your passenger side compartment and you will NEVER have to take a blunt object after your car (well at leatst for a steering issue) again.
Old Jun 17, 2018 | 09:39 AM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Please step away from the hammer!
steig and billschroeder5842 have given great advice!
Old Jun 17, 2018 | 11:16 AM
Martyn's Avatar
Martyn
Thatns Guys, I used the hammer to get the wheels straight,, I have the LMC5 unlock kit and the LMC5 here, I got a spare one when I fitted ones to my other vettes I have had,, I knew it was always useful but didnt know I could do this with a vehicle stuck in the locked state? I really appreciate the input very very much
Old Jun 17, 2018 | 11:17 AM
Martyn's Avatar
Martyn
I thought I had one on my shelf,, and I do
Old Jun 17, 2018 | 11:20 AM
billschroeder5842
You have your Fathers day project all figured out
Old Jun 17, 2018 | 12:12 PM
Martyn's Avatar
Martyn
I think I do,,, will let Yall know how it all goes when done,, will have to be tomorrow now but you have no idea how much I appreciate the input
Old Jun 18, 2018 | 12:43 AM
Moved to C5 Tech.
Old Jun 18, 2018 | 05:02 PM
Martyn's Avatar
Martyn
Well the LCM5 with the additional unlock kit worked a charm, I didnt think it would as it was stuck in the lock state and I know the lock relay was probibally toast, I have fitted many LMC5s before but none to a car that was stuck in the lock state,, a BIG THANK YOU to all those who have offered advise,, I greatly appreciate it
Old Jun 21, 2018 | 10:35 AM
friou's Avatar
friou
I'll just throw this in to the discussion. The "Unlocker" from Compliance parts works like a charm when dealing with a locked column.. Can't over estimate the value and effectiveness of the LMC5 and Unlocker combo.
Old Jun 21, 2018 | 11:20 AM
Martyn's Avatar
Martyn
Oh I totally agree,, I see what it does by applying power direct to the motor with the BCM disconnected but Richard is awesome at Compliance I would recommend him to all C5 owners
I have done this MOD so many times but never with an already stuck and locked column
Only time it would be an issue is if the motor was defective then you have a little more messing around to do
I have re ordered another KMC5 as I keep them on the shelf as I do mess around with a lot of corvettes
To Steering lock stuck in LOCK, Help Needed
