Fog lights wired as running lights???
Does anyone know if this has been done... Or why it should NOT be done:
Could generic fog lights be added and wired into the DLR wiring so they are on all the time as running lights - with NO switch to activate them?
I would be using something like this... LED/COB Angel Eye type fog/running lights, 10W each / 20W/pair.
Re: https://www.ebay.com/itm/2-5-LED-Fog...UAAOSwnQhXpThk
My car does not have (and has never had) factory fog lights.
Ugh, didn't think of that.
Thanks. I should have known that'd be too easy.
Radio Flyer a forum vendor may have the answer.
WetMountainMan (06-20-2018)
yes. All precautions should be taken when installing supplemental lighting and electronics. adding a switch, fuse and relay on its own circuit is way easier than trying to tap into the factory DRL / turn signal. IMO
But how often are turn signals on. 90% of the time they are not in use. So it flashed when you turn. I put some led strips on mine and I love it. Got them at Autozone and double stuck them at the bottom of turn signal housing. Wire splice into the DRL line.
