adding a/c freon
Old Jun 22, 2018 | 10:22 AM
dillon815's Avatar
dillon815
1st Gear
Default adding a/c freon
2002 c5 I want to add Freon but the a/c will not stay on, can I still add the Freon?
Old Jun 22, 2018 | 10:45 AM
Moved to C5 Tech.
Old Jun 22, 2018 | 11:20 AM
huesmann's Avatar
huesmann
What do you mean that the AC will not stay on?
Old Jun 22, 2018 | 11:21 AM
sstonebreaker's Avatar
sstonebreaker
The A/C cuts off automatically when the freon pressure drops. As you start filling the system, the compressor will cycle for longer and longer until it stays on.
Old Jun 22, 2018 | 03:45 PM
Tony S45's Avatar
Tony S45
Had that problem with a Cadillac. Turned on the engine and A/C early in the morning in a cool temperature with the hose connected to the fill valve. Immediately pumped freon into the system and it took the charge up to "normal" operating range before the system shut down.
Attempting to fill the system in the heat of the day cycled off the A/C too quickly for it to accept a charge.
Old Jun 22, 2018 | 03:57 PM
GCG's Avatar
GCG
with the previous posts. I just want to add that you shouldn't recharge the system blindly to avoid the risk of overcharging it.
Get a set of A/C manifold gauges. Doesn't have to be top-of-the-line and uber expensive. One from Harbor Freight would be fine (or get a free loaner from an auto parts store).
Although not essential, a thermometer will give you a better idea of the A/C system health. You can get
<b>one of these</b> one of these
for around 5 bucks:
Check both pressures to have an idea of how things are. Take a look at this post. It has detailed instructions to check/add refrigerant.
-These are the CliffsNotes:
Check your pressures against the chart below. Make sure you take your readings with:
  • Engine @ 2000 rpm
  • A/C in coldest setting
  • Fan at maximum speed
  • Both windows down
  • Thermometer in center air vent
When adding refrigerant, pay attention to both pressures, otherwise you might end up with the high side sky-high trying to get the low side to the chart's value.
Let us know how it goes.
Old Jun 22, 2018 | 06:54 PM
DanTTVette's Avatar
DanTTVette
The 2001 C5 takes 24oz of R34a. You can pick up two 12oz cans from the store. No guessing required.
Although I'd recommend fixing the leak if you have one, and replacing any oil, if necessary.
To adding a/c freon
