i'm interested in a QUAIFE differential for the application of torsen versus limited slip
i don't need advice about the difference but about the installation : why it's impossible to install a quaife on my diff ? the pinion gear is too large so it block the attack pinion
see the difference between them :
So maybe someone get the same problem so : how fix it ? what sort of pinion i have to buy to make it work ?
I tried to put a quaife in my c6z diff and ran into a bunch of issues as well... ultimately I got tired of it and sent it back and bought a wavetrac instead... contact RPM and they can probably give you some advice, they were very helpful to me and I ended up sending my stuff to them and let them put it together and it has been going strong since
is the wavetrac have the same using like torsen ? i have a quaife on a 350z and the using is fantastic, it's for that i would like to get the same feeling into my corvette
for the little story, i'm french so i hope my english is undestanding lol
and i hope you understand that i like quaife product and they are very professional : i told them about my problem and they are ok to refund me when i send it back
i'm just disapointed that i could not install it :/
i have make mesure and i think the c6z06 could work but need modification to be ready ... too much for me so i search the diagram of the wavetrac to compare and maybe it will be the good one to make it works well !
