Going to freshen the vette up a little this weekend with front/rear outer tie rod ends, front/rear sway bar links and poly sway bar bushings. Does anyone have any tips or is there anything important to remember? Everything seems pretty simple..Will be the first time doing this on the vette. Thanks
measure the tie rods currently on the car before you install the new ones and install the new ones to those measurements to get the alignment close and then do an alignment afterwards
Will do. It's going directly to the alignment shop afterwards.
So here's prob a dumb question, when I apply the lube do I only put it inside the bushing where the sway bar touches or should I also put some on the outside of the bushing where the bracket touches?
