C5 - Stiff Steering
Old Jun 27, 2018 | 03:38 PM
kcbeancounter's Avatar
kcbeancounter
3rd Gear
Default C5 - Stiff Steering
How stiff is the steering supposed to be on a C5? Seems like mine is very heavy at a low speed or stop,
Old Jun 27, 2018 | 03:49 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
"Feel" is always subjective. Can you tell us about your car and the suspension type? Depending on the RPO, performance steering could feel heavier at slow speed.
Old Jun 27, 2018 | 04:56 PM
kcbeancounter
3rd Gear
01 Coup is all stock. Interestingly enough. It seemed fine when I bought it. Dealer flushed the steering fluid and now the steering sucks. took it back and they say they cannot find anything wrong with it. It drives fine, but it's like driving my old '56. Takes muscle at slow speed and at a stop.
Old Jun 27, 2018 | 05:34 PM
c4cruiser's Avatar
c4cruiser
Is there any squealing noise when you turn the wheel at slow speeds? Does the steering wheel have any indication of "chatter" or shaking back and forth when turning at slow speeds? Squealing can indicate the serp belt slipping due to wear or a worn tensioner. There may be something clogging the pressure hose or it has broken down inside.
Old Jun 27, 2018 | 05:44 PM
ArtClassShank's Avatar
ArtClassShank
Probably wise to bleed the steering. Either lift the front and steer lock to lock while running or go to a parking lot and do some figure 8's. Check fluid, pull the cap and read the dipstick. Pull the codes as well. If the Magnasteer is unplugged it will default to heavy steering.
Old Jun 27, 2018 | 06:50 PM
Fast one's Avatar
Fast one
Hook a small scale like a fish scale to the outer edge of steering wheel and measure the force tangent to the rim required to move it parked at idle then compare to another C5. This way you will know the actual applied force with no guessing, there must be a factory spec on this somewhere.
Old Jun 27, 2018 | 11:24 PM
Moved to C5 Tech.
To C5 - Stiff Steering
