Alignment question
Old Jul 1, 2018 | 07:45 PM
bwill03z's Avatar
bwill03z
Default Alignment question
Got the car finished up this evening with all new tie rod ends and sway bar links. The front tie rod ends were threaded on the inner tie rods with the same exact amount of threads showing left. I noticed that the rears were not. The pass side was showing about 15 threads left whereas the drivers side was showing maybe 20some threads left. I put the new tie rod ends on with the same positioning as the old ones because I actually had a four wheel alignment done not lobg ago.. I am going for an alignment tomorrow so no big deal. Anyway after getting the car back on the ground I noticed the drivers side tire sticks out alot farther than the passenger tire. Is this because of the tie rod not threaded up as far? I had a four wheel alignment done not that long ago so this seems odd to me. Hopefully it will be corrected tomorrow with an alignment.
