Wheels Leaking Air?
Old Oct 21, 2002 | 04:14 PM
BigLew's Avatar
BigLew
Default Wheels Leaking Air?
Bought a set of Z06 chrome wheels from a vendor in fla. They are not oem. I have had the chev story replace the o-ring on the sensor for the left front 3 times, but it still leaks. Needs air every 2 days. Chevy store doesn't know what to do. Any suggestions :confused: :mad
Old Oct 21, 2002 | 04:47 PM
Mike Mercury's Avatar
Mike Mercury
Default Re: Wheels Leaking Air? (BigLew)
Years ago I bought a complete set of machined aluminum mags... two of them had leaks where the machining was too thin.
How did I determine that? dunk the wheel with tire in a swimming pool and was aboe to see where the air bubbles were esacping from.
Old Oct 21, 2002 | 05:11 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: Wheels Leaking Air? (Mike Mercury)
Sorry to hear about your wheels leaking air... If you dont have a swimming pool and you dont want to borrow your neighbors at midnight... mix up some dishwashing soap and water in a spraybottle and spray the wheel and tire down real good. You will see in a few seconds or at the most a few min. where the assembly is leaking. :yesnod:
vetterdstr :cheers:
Old Oct 21, 2002 | 05:12 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Have you called the vender of the wheels? Some aftermarket wheel makers send a thicker/different design set of o-rings for their wheels. Sounds like you are using the OEM o-rings on a wheel that isn't exactly like the factory wheel, thus you'll need the thicker o-rings.
Tom
Old Oct 21, 2002 | 05:37 PM
gojo's Avatar
gojo
As you know Mike, I have wheels from the same vendor and they don't leak at all. They are better than stock. I assume we received the same o-rings with our wheels. Suggest you try submerging the wheels. Even if the tire people say they did it. They may have sprayed them and that is not always full proof.
[Modified by jfpilla, 8:36 PM 10/21/2002]
Old Oct 21, 2002 | 05:45 PM
BigLew's Avatar
BigLew
Default Re: Wheels Leaking Air? (jfpilla)
they know they are leaking, just not sure how to fix the problem. They have replaced the o-rings 2 times already. :mad :mad
To Wheels Leaking Air?
