Hi,
failed inspection today 2 systems not ready because i resen a previous code p 0410c
current codes
10 pcm p0410hc
20 tcs no codes
40 bcm no codes
58 sdm no codes
60 ipc no codes
80 radio no codes
99 hvac bo 367 h
ao ldcm u1064h
ai rdcm u 1064h
a6 scrm u 1255h
boraa no codes
i'm thinking it is only because of the 10 pcm p0410hc
i tried to spray injector cleaner and wd 40 through the hose for the codule chased by compressed air as stated in another post and obviously this is not working for me
help will be appreciated from any and all .
Wondering the cost from chevy dealer to dagnose this and possible cost associated for the repait
that code is for the air pump which is pretty useless anyway... it might be cheaper to find a tuner that can turn those codes off for you so you can pass inspection rather than diagnosing and repairing the faulty part(s)... it is only used on cold starts to help warm the cats up sooner to reduce emissions and that's it, you wouldn't even notice the difference in how the car runs if it was functioning normally or not at all
It will definitely be a lot cheaper if you are planning on going to the dealer. Find a turner and be done with it.
