dual zone hvac control head problem
Old Jul 8, 2018 | 01:27 AM
Ron W's Avatar
Ron W
8th Gear
Default dual zone hvac control head problem
you may have seen my other post, but let me clarify. My problem is that the passenger side control **** does not change the temp setting for that side. The AC works but only according to the drivers side control ****. there seems to be confusion as to what the passenger side **** is suppose to do. When I got the car the passenger **** worked until the compressor leaked the freon out. The compressor was changed but nobody including the local Chevrolet mechanics can get the passenger side to work again. I also have a 2004 Yukon and a 2006 Cadillac DTS with dual zone controls and they both work like my C5, 2000 corvette should work. I have tried the suggested fixes, remove fuse #27 from passenger foot well fuse box and also disconnecting battery for about 30 minutes. neither of these fixed the issue. The head unit worked fine before the compressor went bad. A corvette expert told me that when the freon is low the system goes into a default mode where only the drivers side works. Does anyone know if this is true? My system is supposedly fully charged according to the Chev dealership who installed the new compressor and tube at a cost of almost 1900 dollars. Please let me know if you have had this problem
Old Jul 8, 2018 | 01:56 AM
grantv's Avatar
grantv
You know that the PS control only adjusts relative to the DS? Left of indent is cooler than DS, right is warmer, indent is same.
Old Jul 8, 2018 | 02:06 PM
GCG's Avatar
GCG
Originally Posted by Ron W
you may have seen my other post, but let me clarify. My problem is that the passenger side control **** does not change the temp setting for that side. The AC works but only according to the drivers side control ****. there seems to be confusion as to what the passenger side **** is suppose to do. When I got the car the passenger **** worked until the compressor leaked the freon out. The compressor was changed but nobody including the local Chevrolet mechanics can get the passenger side to work again...
At what temperature is the driver's side set?
This is the way the dual-zone HVAC system works in a C5:
When the passenger side is set to the 12:00 (center) position, the driver and passenger side are both set to the temp selected by the driver's side, then the passenger can vary his/her side slightly up and down if desired. This is how it works, unless the driver is set to full up (90°F) or full down (60°F), then the passenger setting will have no effect.
The display will not change with the passenger adjustment.
Old Jul 8, 2018 | 04:29 PM
Ron W's Avatar
Ron W
8th Gear
When I first got the car the passenger side display DID change as the passenger side **** was turned and only stopped when the compressor failed. This is also the same for my 2004 GMC Yukon and my 2006 Cadillac DTS.
the control unit shows a temp for drivers side and passenger side both. Why is there so much confusion about this? If other C5 owners have cars that have dual zone control units please let me know if your passenger side display adjust when the passenger side **** is turned or am I just crazy. 2 different techs have told me that when the compressor failed the car went into a default mode that stopped the ps from working.
Old Jul 8, 2018 | 04:39 PM
Ron W's Avatar
Ron W
8th Gear
Please don't respond with what you have only read, please only respond with real life experience you had/have with your own car.
Old Jul 8, 2018 | 04:43 PM
Ron W's Avatar
Ron W
8th Gear
the passenger side is inactive only if driver side is set to 60 or 90 degrees, maximum cold or maximum hot.
Old Jul 8, 2018 | 08:28 PM
C5Rad's Avatar
C5Rad
Cruising
I have a 2001 and the passenger temp control does NOT change the display. It works exactly as described above by making a small adjustment to the passenger vent temperature based on the driver setting.
Old Jul 8, 2018 | 08:55 PM
GCG's Avatar
GCG
When I first got the car the passenger side display DID change as the passenger side **** was turned and only stopped when the compressor failed...
Your mind is playing tricks on you
Old Jul 9, 2018 | 09:52 PM
grantv's Avatar
grantv
Yep. Turning the PS control doesn't show anything on the display. Confirmed on my way from work today.
To dual zone hvac control head problem
