Head Recommendations
Old Jul 9, 2018 | 08:25 PM
JBoyle997's Avatar
JBoyle997
Default Head Recommendations
So I decided on a cam. Going with the BTR stage 3. Does anyone have a good head set up suggestion for that cam? Looking at the Trick Flow 205's and 215s. Car is an 02 z06, I dont plan on adding boost or a spray in the future. Looking for a nice all motor set up. Thanks!
Old Jul 9, 2018 | 11:26 PM
493lszosix's Avatar
493lszosix
TEA ported Trickflow 215’s are a great set of heads and they can do turned down ls3 hollow stem valves if you want to turn high rpm
Old Jul 10, 2018 | 06:59 PM
ASRoff's Avatar
ASRoff
I'm a fan of the mast Small bore heads... But then again Cary Chonaird and I went to High school together... LOL!
Old Jul 11, 2018 | 08:50 AM
maj75's Avatar
maj75
How much power are you looking for? I made 440hp with stock LS6 heads and intake on my LS1.
Old Jul 11, 2018 | 09:05 AM
Arvalo's Avatar
Arvalo
was that including the LS6 cam or just the heads/intake and a tune?
Old Jul 11, 2018 | 02:12 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Can't go wrong with Trick Flow, AFR, Mamo, or Mast. My gut would be TFS CNC 215s turned down LS3 valves, powdered metal guides, and stock rockers with a CHE or Straub trunion upgrade.
If you have decided on the BTR cam give them a call, they can help you decide on the best set of heads for your budget and goals. Last time I called BTR, Brian answered the phone.
To Head Recommendations
