Help with codes
Old Jul 11, 2018 | 12:34 AM
almosttherec5's Avatar
almosttherec5
Default Help with codes
So my AC vents were not working, so I knew the line in back of intake was prob the reason. I undid the MAFand injectors and slid the intake forward, repaired the line, and slid it the intake back, bolted it up, reconnected the MAF and injectors... vents work properly.. but the car is wanting to die sometimes and ruff idle... the car has HCI and full supporting mods... these are the codes I pulled... any idea?? I didn’t disconnect the battery but surely that didn’t cause all this
please any help,
Old Jul 11, 2018 | 01:37 AM
FoxZ06's Avatar
FoxZ06
Any code with an "H" next to is means "History" meaning it is no longer active and can be ignored. Anything with "C" next to it means "Current" and it is a current code that needs fixed.
Old Jul 11, 2018 | 01:41 AM
FoxZ06's Avatar
FoxZ06
I would be looking for a vacuum leak somewhere. Make sure all the lines are back onto the intake. Since you slid the intake off, you possibly disconnected the vacuum line on the rear of the intake. Check that one out. Can reach it from the passenger side (barely).
Old Jul 11, 2018 | 03:07 AM
almosttherec5
I cleared all the codes, and started the car, that’s what came up, but I’ll look for a vacuum after work in the morning
To Help with codes
