A/C Won't Take Charge
Old Aug 26, 2018 | 10:14 PM
redzg's Avatar
redzg
So tomorrow, hook up both gages but don't start the car and see if the high and low are the same. Black death is kind of a universal term to refer to several variations of crud developing within the refrigerant system:https://kevinscarrepair.com/auto-rep...uto-ac-system/
Old Aug 27, 2018 | 07:04 AM
huesmann's Avatar
huesmann
So you want me to check the static pressures? Should I then check the running pressures again right after?
Old Aug 27, 2018 | 09:14 PM
redzg's Avatar
redzg
Silly question first -- are your sure your can tap tapped the can? I assume the tap is still on the can, and if so does it vent energetically if you crack the valve without hooking it up to the gage set? Reason I ask is that I have one can tap that only partly taps. Which also means I have a can of R134 I can't really ever use...
Not trying to pretend to be an A/C expert here -- I am not one! -- but from what I've seen and read it should be interesting to see the static. You should have static pressures on the order of ambient temperature, i.e. if it's 80 degrees you should have something like 80 psi static on both high and low gages -- a lot of good information here:
https://axleaddict.com/auto-repair/D...sis-by-Symptom
and Scotty Kilmer is always entertaining:
Old Aug 27, 2018 | 09:35 PM
huesmann's Avatar
huesmann
Yep, the tap pierced the can—I emptied it topping off another car.
