Dewitts Radiator hole/leak
Old Jul 16, 2018 | 10:00 PM
z0stix's Avatar
z0stix
Default Dewitts Radiator hole/leak
Well I started noticing burned coolant smell and water puddle up after I parked. Found the leak, i dont understand how a hole can be made there, it's on the backside where the fans go, my friend said maybe a rock got caught up and the fans sent it flying into the tube?? doubt it...anyways...I tried brazing it, but no luck, that's why it actually looks worse now...can this still be fixed? or is it a paper weight?
Old Jul 16, 2018 | 11:28 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I don't know about the fan throwing anything but a piece of debris could get between the fan shroud and core face and rub a hole in the tube. Most of the shop do this kind of thing
Old Jul 17, 2018 | 12:16 AM
Ceedub53's Avatar
Ceedub53
Originally Posted by 8VETTE7
There are aluminum, plastic and epoxy type radiator tube repair products out there on the market. Not advocating them nor do I have any personal experience using them . Just saying there are possible solutions to scraping an expensive radiator......
Glad to see Mr Dewitt has offered up a solution.
If you are not confident to do the repair, by all means take it to a radiator shop and have it fixed. DeWitt's is a top tier radiator, worthy of a fix.
Old Jul 17, 2018 | 12:32 AM
z0stix's Avatar
z0stix
not many good shops here, I live in a small town, everyone is afraid of the aluminum
Old Jul 17, 2018 | 04:38 AM
Brackets's Avatar
Brackets
My first thought upon seeing that pic was that something wore through it.....
Old Jul 17, 2018 | 06:50 PM
z0stix's Avatar
z0stix
at first it was a pin size hole, when I used a dremel to clean it up it got worse
Old Jul 17, 2018 | 07:30 PM
Brackets's Avatar
Brackets
Okay, that would explain it.
Old Jul 18, 2018 | 08:29 AM
Robrote's Avatar
Robrote
This radiator is now junk. I will paypal you $50 to get it out of your garage and free up space.
Old Jul 18, 2018 | 09:41 AM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
I don't think so. Some of the zinc brazing rods work quite well if you practice. Also, a highly skilled tig welder could close that up. Even epoxy (not JB weld) holds really good.on aluminum. The two part stuff in pump syringes but keep in mind, once you try this welding is no longer an option.
Old Jul 18, 2018 | 10:25 AM
Robrote's Avatar
Robrote
I was tongue in cheek, of course.
Old Jul 20, 2018 | 01:07 AM
z0stix's Avatar
z0stix
I think I just made it worse...tried brazing it, it came out ok the first time, but I still saw a super small pin size hole, so I decided to re do it....damn I made it worse....should have left it alone....200 shipped anyone??
To Dewitts Radiator hole/leak
