Ground connector
Old Jul 19, 2018 | 05:13 PM
Golfingbob's Avatar
Golfingbob
Default Ground connector
well I am trying to check the ground for the ebcm that is located near the driver side headlight. How do you separate it to check the contacts are inside once you remove from grounding post. Don’t want to break it. This connector looks different from others. Never had this problem before. I know it must be simple?? 2002 coupe.
thanks for help.
Old Jul 20, 2018 | 04:43 PM
Golfingbob's Avatar
Golfingbob
Tried against n today. No luck figuring out how to separate connector
Old Jul 20, 2018 | 05:07 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Are these the 2 grounds you're speaking of ??...If I can remember there are tabs on either end you have to push in !!...if I have time tonight or tomorrow I will take a pic or video...I know, the first time I did it it was like... WTF ???? ...it separates at the nut end !!
Old Jul 20, 2018 | 05:12 PM
Golfingbob's Avatar
Golfingbob
Yes that is correct. That would be great if you could send me a picture or video. I have never seen a connector like this. I want to verify the ground first before removing the EBCM. Got the C1214 code.
Old Jul 20, 2018 | 06:12 PM
C5 Diag's Avatar
C5 Diag
I can't remember if you can access each individual wire from the back on the connector...if so and you have a sharp 12v test light tip (connected to battery positive) just pierce the ground wire and if the light comes on you have a ground...then use liquid electrical tape to reseal the hole...but if you want to take it apart that's OK...mine was very clean when I opened it up..I used some fine emery cloth and cleaned each terminal...what year is the car ??
Old Jul 20, 2018 | 07:13 PM
Golfingbob's Avatar
Golfingbob
2002. Just going to take it apart first.
Old Jul 21, 2018 | 09:19 AM
C5 Diag's Avatar
C5 Diag
just an take a thin screwdriver and lightly pry on this end of the connector nearest the ground lug and it will separate...do the same on the other side !!
To Ground connector
