Abandoning front cigarette lighter
Old Jul 21, 2018 | 04:36 PM
Oklahomaboy's Avatar
Oklahomaboy
Default Abandoning rear cigarette lighter
I have remove the cigarette lighter from the glove compartment and replaced it with a hdmi and usb receptical. What is the correct and safe thing to do with plug? Cut it off and terminate the ends or just tape the rascal up?
Old Jul 21, 2018 | 04:46 PM
rrwirsi's Avatar
rrwirsi
The cigarette lighter should be in the compartment with a flip door below the A/C/heat controls unless someone has already relocated it to the glove compartment. Me, I would just put a plug in and be done with it.
Old Jul 22, 2018 | 03:50 PM
BIGWILL_88's Avatar
BIGWILL_88
Default Here's what I did
I Turned mine into a dual usb outlet. I purchased a leather wrapped bezel that already had a hole in it so I decided that I'd take the front cig lighter and turn it into something I could use. I simply spliced the wires and put the female ends on them and attached the usb socket and it works perfectly.
Old Jul 22, 2018 | 04:12 PM
jrprich's Avatar
jrprich
USB voltage is usually 5 volts DC.........12 volts DC might fry a USB powered device
Old Jul 22, 2018 | 04:31 PM
BIGWILL_88's Avatar
BIGWILL_88
Default That's the continual voltage reader
It works just fine, no problems at all.
Old Jul 22, 2018 | 07:14 PM
UM Rebel's Avatar
UM Rebel
That's pretty cool.. Where did you get that plug?
Old Jul 22, 2018 | 08:34 PM
BIGWILL_88's Avatar
BIGWILL_88
Thanks! I ordered the plug off of amazon but had to fabricate the holder that it's in to fit the pre-drilled hole.
Old Jul 23, 2018 | 09:57 AM
bravo29's Avatar
bravo29
I did the same no issue in mine. Bought a dual lighted USB and put in where the cigarette lighter was. I had to run different power wires as mine didn't turn off when the key was out. The dam light would stay on.
To Abandoning front cigarette lighter
