Slight Differential Whine at 70 mph
Old Jul 25, 2018 | 09:48 AM
jost6453's Avatar
jost6453
Default Slight Differential Whine at 70 mph
I have an '02 coupe 6 MN that just turned 47k. I bought the car last winter so this is my first summer driving it. I've only taken a couple long road trips with it, but recently noticed slight high frequency 'whine' at approx 70 mph. It does it in 5th or 6th gear, so I'm reasonably sure it's the diff gears. And I only hear it when under load. If I go down a hill or back
off the gas, it goes away. It's not bad I enough to spend big $$ on a repair (yet)..... so I'm wondering if others had any luck using a different gear lube to quieit it down. I've seen moly additives and other lubes that claim to help but am looking for some real-world feedback. Thanks to all!!
Old Jul 25, 2018 | 09:59 AM
mhanley's Avatar
mhanley
I would change the fluid in both the tranny and the differental using GM products or Lucas Oil products.
Mike
Old Jul 25, 2018 | 11:27 AM
Moved to C5 Tech.
Old Jul 25, 2018 | 11:55 AM
99blkfrc99's Avatar
99blkfrc99
Been quite a few of these posts this year, myself included. It won't get any better with a fluid change. Just start saving for a rear end rebuild.
Old Jul 30, 2018 | 09:07 PM
ALLEGRO's Avatar
ALLEGRO
I think its tranny whine.
My 94 Trans Am GT too had the T-56 and it too had a whine about the speed you are describing.
Move forward to my 03 AE MN6 and the same outcome.
Suggestion, get a louder exhaust or turn the radio up a bit.
Good luck
To Slight Differential Whine at 70 mph
