Torque Tube Rebuild Pre-planning
So pulling the TT will facilitate the R&R of a few other items that might require maintenance or replacement.
I 'm one that will replace any part or component during this process as doing this again is not my plan.
So my question to those who have "been there" and "done that" is what parts can I expect to remove/replace?
I'm not worried about spending a few extra bucks.
Clutch? Slave cyl?
Upgrade the tunnel plate?
Any suggestions are welcome
The list so far;
SPL Performance, GM Parts, TickShift, Elite Engineering, Carolina Clutch
Carolina Clutch LS7 Luk Heavy Duty Clutch Kit ----04-905
Carolina Clutch LS7 Stage 1 Clutch Kit and Flywheel Package --- CC-04LS7-C5
GM Rear Main Seal --- 89060436
Fel-Pro Rear Main Seal Cover Gasket 1-Piece Rubber LS2 LS3 LS6 LQ9 LQ4 --- BS40640
Tick Shift Torque Tube Bearing Kit --- STTTBK9704
Tick Torque Tube Bushing Kit 10mm --- 585123 12mm 585113
Tick Adjustable Master Cylinder Kit --- TAMCKYB
Tick Remote Clutch SPEEDbleeder --- TPSBL
Tick & McLeod Twin Disc Clutch --- 68462
Summit Skip-Shift Eliminator --- SLE-21008
Great installation & documentation thread from SaberD https://www.corvetteforum.com/forums...dies-pics.html
Tick & McLeod Twin Disc Clutch http://www.tickperformance.com/tick-...-corvette-z06/
Carolina Clutch LS7 HD http://www.carolinaclutch.com/inventory/2275-luk-stock-replacement-clutch-kits-04-905-chevy-corvette-ls7-luk-heavy-duty-clutch-kit/
Carolina Clutch http://www.carolinaclutch.com/invent...8%2Fl%2F5.7%2F
Upgrade Tunnel Plate http://www.eliteengineeringusa.com/1...h-thermal-abs/
Tick Remote Clutch SPEEDbleeder Line http://www.tickperformance.com/tick-...-firebird-ls1/
Clutch? Slave cyl?
If you are familiar with this project, could you also list specific gaskets that would need replacing from bell housing to rear diff and any "specialty" tools (ie. pilot bearing puller) needed to complete all aspects of this job.
I'm hoping to collect a list of parts and vendors that might make this thread a future sticky.
Check your clutch while you're in there and change the pilot bearing.
Use a stock GM pilot bearing, no solid one as this will kill your input shaft and those things are f***ing expensive.
Next
LS6 Flywheel and clutch 52lbs
Tunnel Plate and heat shield $300
Heat shield only $125
Fuel Filter
LINGENFELTER Adjustable Clutch Pedal Stop
